Wiring harness charge circuit available??
Discussion in 'General Chevy & GM Tech Questions' started by dgajr, Aug 29, 2009.
  1. dgajr
    dgajr New Member
    2004 Suburban with the factory wiring for the trailering package. I would like to charge a battery on a trailer as I tow it.
    Does anyone know if these trucks came with a charge circuit prewired that I can use in the existing 7 pin harness.
    Thanks,
    David
  2. Jimmiee
    David,
    You have to run a fused wire from the battery back to the plug.
  3. dgajr
    dgajr New Member
    There is a red wire to the trailer connector identified as a "BAT". It is a larger gauge than the others (looks like a #12 awg). There is no voltage on it, even with the ignition on.
    I would think this terminates somewhere, hopefully in the fuse box.
    Anybody know?
    Thanks,
    David
  4. Jimmiee
    Look in the Power Distribution Box for a missing fuse. The truck is delivered without this fuse and you need to install one.
