Wiring Setup '96 Suburban
Discussion in 'Towing & Trailer Tech' started by mnmhays, May 31, 2014.
  1. mnmhays
    mnmhays Member
    I will test to be sure but logic tells me that my reasoning is what should work. Reverse light is the wild card, as it has been a recent addition to most setups. A mechanic friend of mine was saying that 7 pins usually run just 6, leaving the reverse light dummied off if it's not readily available. I figure that since I most likely have it, I will wire it in.
    The beauty of the 4wires in the OEM harness is that they are meant to be T-ed into, since they run the the vehicle's turn, brake, reverse & running lights.
  2. Crawdaddy
    Yep, reverse lights on a trailer are finally starting to be a thing on the larger 5th wheels, and slowly creeping into smaller campers. But if you have the wire already in your trailer prep harness (I did too on my 91 'burb) why not hook it up. I plan to add reverse lights to my camper eventually.
  3. RayVoy
    Does it show now, I logged off and it is there.
    The same one used in the US, but there is a difference between the pic in post 8, and the one in post 5, the colours are different, and the designation for the center terminal is different (I think in the original assignments for the 7 pin connector, the center pin was for whatever you wanted).
  4. mnmhays
    mnmhays Member
    Still no pic for me...must be my computer.
    Final question; Where is the wire under the dash for the red brake controller wire to connect to?
  5. RayVoy
    Try this,
  6. mnmhays
    mnmhays Member
    Got the pic now, thanks!
    Last thing I'm having real trouble with is the red wire from my brake controller to the stop light switch...where is the wire to hook that into. I pulled the lower dash cover and I'm not getting to anything through there. I saw a thread about a spot on the relay block but I have no connectors to plug into.
  7. Crawdaddy
    The brake switch is waaay up on the brake pedal, in a nearly impossible to get to spot. I do remember reading that the connector block in the drivers footwell has a spot that's tied into the cold side of the brake pedal, but I don't remember which one it was. Some probing with a multimeter while pushing the brake pedal should sort it out pretty quick.
  8. mnmhays
    mnmhays Member
    The spade connector on the control block is only on '99 & up.
    I did finally find the wiring harness that leads out of the switch...there are about 7 or 8 wires in it. After some consultation with my Chilton Manual and a mechanic friend (He's primarily a Chrysler mechanic)...we deduced & tested that it is the white wire leading out of the switch...Bingo! We're in business!
  9. Conlan Rose
    The thread I think you are both referencing is I think the one I posted about a similar question. Glad to know that now I have an answer to which wire it is LOL.
