would 285s fit
Discussion in 'Lifted & Offroad Suspension' started by 03 SIERRA, Sep 1, 2010.
  1. 03 SIERRA
    03 SIERRA Rockstar
    i have an 03 sierra 4x4 would 285/75/16 fit with the stock rims, and wothout trimming my main plastic fachia?
  2. silveradotrailblazer
    You will need a leveling kit with that size tire. Yes they will work with the stock rims.
  3. ajarman
    X2 I had 285's on my '07 classic with stockies, but had to get keys to stop the rubbing.
  4. 03 SIERRA
    03 SIERRA Rockstar
    what if i just crank the t bars
  5. silveradotrailblazer
    Every truck is alittle differant. Some trucks you can crank the bars enough without ruining the ride others you can't. Before you try cranking the bars measure from the front wheel center cap to the fender on both sides. Write these measuements down and save in case you want to return the bars to the stock settings. Usually you get a 1/4" of lift with 1 complete turn of the torson bar bolt. You should lift the front of the truck off the ground when you make adjustments. Make you adjustments a little at a time, lower the truck and take for a ride so the torson bars can settle in with the new adjustment. If you need to make more adjustments. I know this sounds like alot of work but its the best way to adjust the bars.
  6. clgoch187
    clgoch187 Rockstar 4 Years 500 Posts
    i got 285/75/16 bfgs on my 03 z71.....all stock and no rubbing
  7. silveradotrailblazer
    As mentioned, every truck is a little differant and Z-71's do sit higher because they have stiffer torson bars from the factory. The bars used on Z-71's are also used on 3/4 ton trucks.
  8. 03 SIERRA
    03 SIERRA Rockstar
    so z71 1500s have 2500 tbars
  9. silveradotrailblazer
    Yes they do. There are several differant 3/4 bars and the Z-71 gets the lightest or softer of the 3/4 bars.
  10. Dirtysailor
    Dirtysailor New Member
    Have a 03 Chevy WT model all stock and never rubbed anything with 285/75/16 after 50K miles.
