You think these are good wheels and tire for me?
Discussion in 'Wheels & Tires' started by Runnerboy23, Nov 9, 2010.
  1. Runnerboy23
    Runnerboy23 Rockstar 100 Posts
  2. mccombs310
    mccombs310 New Member
    What kind of driving do you do? A lot of on road,offroading,gravel. In order for us to help you decide we need to know how,where and what you drive.
  3. TELORVEHC
    What year truck do you have? Since you have a leveling kit you can probably go bigger tire-size wise. But just judging from the picture they look good. As for the wheels, I happen to like the look of streetlock (fake beadlock) wheels.
  4. ridick_bowen
    ridick_bowen Rockstar 100 Posts
    These will fit no problem.
    Them Nitto Grapplers are the ****.
  5. ntbush83
    I agree you definitely should go bigger on the tires. with the leveling kit I'd say at least 285's
  6. ridick_bowen
    285? That's just wider, not bigger.
  7. mccombs310
    They will be a bit taller also. Bigger is always better.
  8. HawaiiKid
    HawaiiKid Rockstar 4 Years 500 Posts
    I think he meant with the same ratio, 285/70 rather than 265/70. 265/70 is a stock sized tire on my year Silverado, so they aren't very big-I would go bigger too.
  9. ntbush83
    Thank you Hawaiikid I did not clarify myself. I knew someone would call me out on that one. Yes I meant with the same ratio so its wider and taller :)
  10. randomsandwhich
    randomsandwhich Rockstar 3 Years 100 Posts
    well assuming you have a nbs silverado, those wheels should work, however with the +18 offset running 285 tires expect possibly some tire rub on the uca .. 5.25 is the ideal backspacing for nbs silverado, 5.5-5.7 would be pushing running a 9 inch wide wheel. If you anything older then 07 don't listen to anything I just said, I can't vouch for the older trucks.
