    Join Today ~ It's Free
Z71 2wd into Z71 4x4
Discussion in 'GM Powertrain' started by CJohnston, Jan 28, 2013.
  1. CJohnston
    CJohnston New Member
    I want to turn my 2wd into a 4x4 I got a great deal on the truck and dont want to sell it. Its the Z71 package but 2wd. Im sure its more complicated than buying a transfer case front chunk and wiring to hook up the switch. Anyone done this or is it too much trouble. Thanks for the input.
  2. BMason
    BMason New Member
    Unless you can get a donor truck for next to nothing, the costs will be more than the worth. You will need trans output shaft and housing changed, transfer case, front differential, front axles, front hubs, driveshaft, pcm, controls and maybe more that I am missing.
  3. tbplus10
    tbplus10 Super Moderator Staff Member Platinum Contributor 1000 Posts
    Does the truck mean more to you than about $5000, thats a low estimate of having someone do the work for you.
    No offense meant here but if your asking on the internet how to do the job and what parts you need you probably arent capable of doing the work yourself.
    You'll also need to plan other transportation for the better part of at least a month since thats the average time it takes to complete this task.
    You might want to rethink your plans and look at selling this truck and buying a 4x4.
    And yes I do have a bit of experience at this task, I've built over a dozen 4x4's from the ground up and converted probably another dozen, each one is still a learning experience.
  4. CJohnston
    I appreciate the input bmason. Although I suppose I should have specified my question was more along the lines of are the frames on the two wheel drives different from the four? That was my main concern I will have about two grand in parts using used parts. I have done a good bit of research just needed a little extra help. Just wanted to know if anyone has done this exact project?
  5. ahmitchell1
    ahmitchell1 New Member ROTM Winner 1000 Posts
    I feel like a solid axle swap is the best route. What year is your truck? Also do you have a center console cuz I'd go with a floor shifter to make it easier. It's not to fun on newer trucks though
  6. CJohnston
    My truck is an 08 and I thought about the sas, but idk I don't want a super huge lift more less just want about a two inch lift. But I would love a solid axle.
    - - - Updated - - -
  7. ahmitchell1
    I just think it'll be cheaper to get a solid axle even if you are going to inches. If your doing it yourself. One day my 09 will be solid axle. I'm loving these 87s I just got, there last year of the solid axle I believe
  8. shibby2oo8
    shibby2oo8 New Member
    You would need a donor for the frame mounting brackets alone, I've never done it but the differences between the two are too much to justify. Now I think the only saving point is the 07-08 body change removed the old t-bar setup for the coils so that might help on the conversion but I think your sunk.
