Zero Oil Pressure, no other indications
Discussion in 'Chevy Silverado Forum (GMC Sierra)' started by ramgxr03, Apr 22, 2010.
  1. ramgxr03
    ramgxr03 New Member
    I recently noticed that I have zero oil pressure. I have checked the oil many times and have good quantity. There are no other associated bells and whistles with the zero pressure indication. I plan on checking the sending unit but wondering why isnt there any other indication. Any suggestions?
  2. 7daughters
    7daughters New Member
    What year, miles and engine? Does it come up as you bring the RPM's up?
  3. unplugged
    Yikes! Is the oil pressure / check engine light on? Most likely the ops, but I'd check it sooner than later.
  4. vncj96
    Need more vehicle info(year,make,model) if your gauge is working correctly the computer would kill the truck so no damage occurs. Is your truck overheating or knocking?
  5. ramgxr03
    ramgxr03 New Member
    It is an 08 silverado 4wd crew cab with 39K on it. No other lights or warnings. Oil quantity is good, no leaks. No heating problems, no knocking or other noises. There was absolutely no guage response to rpm changes for a while until yesterday when it just broke zero and fluctuated a small amount before falling back below zero.
  6. murdog94
    You are still under the powertrain warranty I would get it into the dealer ASAP.... hopefully it is just the sending unit...
