1 - 4 of 4 Posts
Hello! New here! I have a ‘95 Silverado with a active ABS light on and no Speedo. I have attempted to try and retrieve a ABS blink code between “H” & “A” with a paper clip but I can not get it to blink. I am wondering if I have a “ghost” and it’s not a legit light OR something else is going on that would cause this to occur. Thanks!
Might be a bad output speed sensor, the ABS system on those uses the output speed sensor for the rear wheel ABS. It would also affect your speedometer and cause it not to work if it was a bad sensor. Make sure you check your wiring too.
  • Like
Reactions: RayVoy
Ok, thank you! Your talking about the sensor on the transfer case, correct?
Yes, it reads output speed
1 - 4 of 4 Posts
