Hi all,
I have a 2000 Silverado LS with 5.3L engine, 4 speed transmission, with 80k on the odometer. I just started noticing it shifts roughly from first to second gear, but only when warm, and only at lower RPMs. If I get on it, it does not shift roughly. It also does not do it when the block is cold. It doesnt clank or anything, but its definitely enough of a rough shift to get my attention, definitely shifts rougher than 2nd to 3rd or 3rd to 4th. It may have been doing this for a while I'm not sure, I just started drving easier to save gas and noticed it. Checked tranny fluid and it is nice and red and at the full mark. Any ideas? I'm just trying to avoid the 'try this, then try that' until its fixed, cause that can get pricey! Would it be the solenoid, or something as simple as a filter/fluid change? I am pretty mechanically inclined so I am able to do a little bit of work myself...anyone have any advice?
Thanks!
-Rob
Thanks!
-Rob
