1 - 2 of 2 Posts
hi guys
i am thinking i have a parasitic draw and need some advice. I have an 01 yukon 5.3l
my problem first started a few months back. my battery was 1 year old and i went out and yukon i tested alternator and its putting out 14.5-15 volts so i know its working. i took my battery back figuring it was faulty and of course they had to put the charger on it to verify before i could return. it took the charge and held it so now i am thinking ok well something is drawing the power out of it. put battery back in and 2 days later dead again. that was awhile ago and havent had time to check it out.. today i said ok i gonna start fresh, i bought a brand new battery and tested with my meter. 12.49 volts ok good. connect amp meter to it, starts at 2.60 drops to .02 in about 20-30 secs time. im like ok it doesnt seem like any power draw going on here.. watch the meter for a good 5 mins or so and does not change. just to check i open the door and take the reading, 4.26, close door and check reading it drops to .21 once the interior lights go out. now what i did notice is on my instrument cluster once i shut car off even tho i did not even start the yukon today and its ice cold, after about ten secs i heard a small click and seen that the temp gauge goes to about the 210 mark. i first noticed this a couple months ago when this first started happening, i have another cluster i have another cluster and swapped them out. temp gauge didnt move anymore but battery was still dying, when i first switched it out i thought yeah that was it but turns out it wasnt. ok so i disconnected the battery totally for about 30 mins. the temp gauge is still at the 210 mark. i hooked the positive side up and ran another amp draw test. starts at 2.60 and falls to .01 over about 20 seconds and holds there at .01 . what do u guys think, do i have a parasitic draw or that the other battery i had was faulty?any suggestions or theories?
I'd say parasitic draw, my 06 is doing same after sitting for day or 2. Truck is LOADED even has power AIR LUMBAR on PASSENGER SEAT! My mechanic told me, $50 bucks an hour, could take, a half hour, could take 5 days......... BUT, he suggested, putting a Batt disconnect switch, ie: a knife switch, or key switch, and disconnecting batt if I'm not driving it for awhile. Switch cost $3.98 free shipping on ebay! Hope this helps!
1 - 2 of 2 Posts
