1 - 2 of 2 Posts
I want to replace my factory headlights and taillights. Can anyone explain how to remove the factory headlights, and if so, has anyone changed their headlights? I am in the process of changing my taillights as well. I have purchased the altezza black taillights by IPCW.
Thanks for your help!:redface:
headlight removal
It's very easy, it has two pins one on each side of the unit. Pull it forward then up then the next side and the headlight comes loose. Carefull when u pull the last one out the headlight could fall down. Good luck and post a pic. when you're done
1 - 2 of 2 Posts
