Stolen from Four Wheeler magazine. These new parts debuted at the SEMA show.
Better mileage:
For the Duramax equiped 4x4's it just became easier.
Gear vendors overdrive has a new bolt on overdrive, improves fuel economy by 20% for 4x4's with 4.10 or lower gearing, gives greater gear choices when towing.
www.gearvendors.com
More power for small block Chevy:
Pedestal series S/B rocker arm system, designed to bolt on and maximize valvetrain efficiency for popular GM 350 cylinder heads.
www.prw-usa.com
Exhaust cut outs:
From Race Ready comes a new 5" exhaust cut-out, electrically operated by the push of a button. Designed for Diesel engines only.
Call: Call Race Ready Performance @ 866 722-3732
Off Road suspension performance for 8 lug GM's:
Uniball upper control arms, fit 01 to present GM eight lug trucks. Designed stronger than factory items with additional camber adjustment, built in bump stops, and additional shock mounting tabs.
www.cognitomotorsports.com
Emergency Jack:
Titan Air Jack, system uses exhaust pressure or compressed air to jack a vehicle up.
wwwstreamlineimport.com
Oil filtration:
Magnetic oil filtration system that works with most spin on oil filters and uses high strenght Neodymium magnets to retain harmful metalic particles before the filter.
www.paretopoint.com
Chevy Serpentine kit:
Small block Serpentine belt conversion kit. A full kit to convert your existing multi belt GM engine to a single serpentine belt.
www.marchperf.com
Bolt on performance:
CNC small block Chevy heads. High perf. heads with exceptional flow, designed to support up to 650 hp applications.
www.trickflow.com
Rear view mirror:
Auto Dimming Billet Mirror
Liquid crystal display that dims to prevent the glare from HID lights encompassed in a Billet aluminium frame.
www.alphamirror.com
Race ready lights:
PIAA has a new shock lamp designed to withstand the rigors of high speed off road racing.
www.piaa.com
LED lighting:
Sealed LED lighting system designed to be affordable.
www.hamsar.com
Better mileage:
www.gearvendors.com
www.prw-usa.com
Exhaust cut outs:
Emergency Jack:
Oil filtration:
www.paretopoint.com
www.marchperf.com
www.trickflow.com
Rear view mirror:
www.alphamirror.com
Race ready lights:
www.piaa.com
LED lighting:
www.hamsar.com
