I assume you are asking about the 4 cylinder equinox. Correct? If so the procedure is to:
1. disconnect the neg battery cable.
2. remove the drive belt.
3. disconnect positive cable from alternator (nut)
4. remove 3 bolts holding the alternator to the block.
Reverse procedure to install. The alt nut torque is 15 foot pounds and the 3 bolts are 16 foot pounds.
