1 - 2 of 2 Posts
Hey guys, as the title says I got a 1987 gmc jimmy s15 2.8L 2wd. It has been sitting for about 6 months do to alternator and battery trouble. I got these things replaced about 2 months ago and got the truck to start. It takes a few tries to get it to start and when it does it will not stay running unless I feather on the gas and still it eventually dies. If I press the gas past a certain point it stalls out like it's about to die. When I let the gas go it acts like it is going to try to run again. I have no check engine light on while running. Their is fuel spraying out of both injectors. The truck will not idle and stay running. If I could get some assistance on this it would be much appreciated.
Discussion Starter #2
Well I changed a few parts and had no luck. Fuel pump, filter, coolant temp. sensor. plugs and wires. No one has replied but maybe this will give you guys some lead. Thanks in advance.
1 - 2 of 2 Posts
