1 - 11 of 11 Posts
My 1990 K1500 350 TBI recently had a NO START condition with NO spark and NO fuel spray at TBI.
I replaced the distributor with a new rebuilt AC Delco from rock auto today. Started up fine, ran a few minutes and died. Restarted a couple times and now nothing. Will not start. Hooked timing light up to #1 wire see if there is spark and yes there is. Seems a little weak, but it's only cranking. There is NO fuel spray, but I do hear fuel pump run in the tank. Before I troubleshoot, I was looking for anyone's thoughts?
Low voltage wiring all connected properly, correct? As in the ICM connections at the distributor, plus the coil connection. Just as a PM step, double check the grounds integrity at the thermostat.
Discussion Starter #3
I just tried again after letting it sit a couple hours while I did something else and it started after a couple tries, but only ran at idle for 30 seconds and died again and will not start.
I believe all wiring is correct. Unless there is an issue with a plug being worn or something. Thermostat ground looks good. Any chance a bad Coolant sensor can make it die like this?
CTS shouldn’t kill it like this.
  • Like
Reactions: Joe Winsor
Hi Joe, after replacing the engine in my 93 k1500, I had a similar problem. I followed the injector wires through the firewall and found no wiring issues in that direction. I then followed the one wire that does not go back to the injectors, but down along the transmission on the driver side. I found cracked insulation and the wire grounding on one of the metal harness retainers. I wrapped the wire and there was no longer a no start problem.
Discussion Starter #8
Thanks for the info. Can you tell me a little more of this wire? Do you know what it was for? Where did it start and end?
Joe,
The wire was not identified on the vehicle schematic. It started from the PCM, went across the bell housing, passenger side to driver side, and then back along the transmission. The wire that shorted was colored pnk/blk. See my photo attached.
168212
168211
Sent with kind regards-
Jack
A bad ignition coil has been known to take out the ICM. You can have the coil tested and it'll tell you if it's bad but, it won't tell you if it's good. If the ICM is bad, it won't tell the ECM the engine is turning so, the ECM won't tell the injectors to fire.
Discussion Starter #11
As it turns our the pigtail connectors at the back of the distributor were bad and needed to be replaced.
1 - 11 of 11 Posts
