Hello, NEED HELP
Cruise worked intermit last week and now not at all.
Have replaced transmission speed sensor, brake light switch, cruise switch stalk.
Verified fuses are good.
Checked for voltage at the connector for the cruise ...
Key switch on...
1. red wire showing 12 volts
2. blue wire shows 12 volts when r/a pressed
3. green wire shows 12 volts when set button pressed
4. gray wire shows 12 volts continuous ...
I believe the gray wire should only have 12 volts when brake applied... since it is showing 12 volts all the time the cruise control thinks the brake is pressed.
Could it be a short in the column?
Key switch on...
