Hi All,
Here's today's premise: My 91 K2500 doesn't enter 4WD hi or lo because the wires going from the 4WD switch in the Transfer Case to the front axle actuator are sliced in half. When I shift to 4WD, the front driveshaft does engage but the front axles do not (expected behavior in this scenario).
What I want to know is: Would it be safe/effective to add a simple toggle switch in the cab of the truck that replaces the switch mounted to the TC, and use this to control the 4WD actuator? If so, would it also be safe to leave the TC in 4-Hi at all times, and simply use the toggle switch to control the 4WD? I understand that the front driveshaft will always be spinning and that there will be a loss of power/efficiency, but I drive ~4 miles a day on sidestreets and I'm not sure I would see a difference. If it would be a major difference/cause problems, I can also use them in combination (shift TC THEN flip 4WD switch).
Thanks.
Thanks.
