What does the Gear selector switch circuit consist of on the 1993 GMC Sonoma??
Murphy Clyde · Registered Joined Dec 18, 2017 · 3 Posts Discussion Starter · #1 · Dec 18, 2017 Only show this user What does the Gear selector switch circuit consist of on the 1993 GMC Sonoma??
RayVoy · Registered Joined Apr 19, 2012 · 18,274 Posts #2 · Dec 19, 2017 Only show this user A code 72 is a speed sensor code. It's in the transmission tail piece (2wd), in the transfer case output shaft area (4wd). Check the wiring firrst
Murphy Clyde · Registered Joined Dec 18, 2017 · 3 Posts Discussion Starter · #3 · Dec 19, 2017 Only show this user Thanks Ray ~ Could this cause the Automatic transmission from going into drive and overdrive??
RayVoy · Registered Joined Apr 19, 2012 · 18,274 Posts #4 · Dec 19, 2017 Only show this user It's (speed sensor) input is required to shift the trans, Is the speedometer working
Murphy Clyde · Registered Joined Dec 18, 2017 · 3 Posts Discussion Starter · #5 · Dec 24, 2017 Only show this user Thanks so much, it is working now!! The speedometer was working crazy, but now it is working just fine.
