1 - 6 of 6 Posts
have been doing little things to my plow burban getting it ready for winter. have been sorting out running issuie? I have been starting it every other day with out any issuies other then the ones i was chasing? all of a sudden my dash went dead?? it start's and runs without the dash but not charging and all of a sudden i have no reverse not sure if related yet?? I have not trouble shot it yet wandering if anybody has run accross this b-4 and what they may have found somewhere to start??
When you say dash are you talking about the instrument cluster? If so it may be a loose ground wire for the cluster. However this should not affect reverse.
Long ago I had an S15 Jimmy. Yes, I know this is a completely different vehicle. However this may be worth a look. I lost my instrument cluster. I knew a mechanic who was very familiar with GM products. He told me to open the driver's side door, get on my knees, and look above the parking brake pedal and I would see a single wire on a ring terminal that screwed down to a section of steel above the parking brake pedal. I found it and it was loose - common problem. Tightened it up and problem solved. Your cluster ground may not be there but it's an easy look-see.
thank you for that. i recently had to removed 3 old alarm systems because of wiring issues. i will go back and revisit those area's and the one you told me about. thank you again
great advice. unfortunately, reverse has nothing to do with any of that wiring whatsoever and is probably a mechanical problem. is it a 4L60E? if so heres a list with the 30 common failures.
It could very well be a wiring problem but highly unlikely.
1. Slow, slipping or no reverse: “lo-reverse” clutches are worn out, fluid leak in the reverse apply circuit, or broken sunshell. It is possible to remedy a fluid problem by removing the checkball from its cage in the case in the rear of the transmission may help (must remove valve body), or adding a high-viscosity additive or other seal restorer product. May also have worn boost valve (can replace in the pan).
1 - 6 of 6 Posts
