I have tried to replace countless things over the past couple months and nothing has worked. I will be driving and it will just shut off with no warning and it wont turn on again until it is cold and sat for a couple of hours. I have replaced the fuel pump, ignition coil, tested the oil pressure regulator since its all on the same circuit. I recently put noid lights to the injectors to see if they were bad but the lights stayed lit which means they arent getting a proper signal. So i replaced the ecm and now it wont start at all. Do i have to reprogram the ecm before putting it in or are there other problems that could be causing this issue. Any suggestions will help greatly thanks!
