1 - 7 of 7 Posts
Make sure the truck is nice and warmed up before you bring it in for a smog test. That is the biggest problem usually.
Take it out for a nice long highway drive and blow the gunk out before the smog check.
That compression does sound low but then with that man miles that is to be expected. The truck doesn’t have to pass new truck standards, just for the year it was made.
If you know the guy doing the test he just might let you rev the engine up to where it will pass. Just a thought.
might run a can of seaFoam in the vaccc side and in the fuel tank and a can of engine restore in a fresh oil change and run for 2 tanks worth of gas and drive untill good and warm and retest....i bet all pickup and passes. i got 321,000 miles and original cats and O2s and she passes just fine and gives me 18MPG out of the 35 still.....mike
Has the cat been replaced yet? Mine gave out at 240k or so. New cat and a 3" catback system only set me back $240.
1 - 7 of 7 Posts
