1 - 4 of 4 Posts
Went to start my chevy and heard an explosion, popped the hood and saw upper intake manifold broken.have not had a problem first time starting before, only problem would be every start after first start. I can replace the upper intake manifold. But need some advice on what caused it?
any help will be great, Thanks
richmchd
There may be a leak in the fuel injection system. If there was gas inside the plastic intake, and it found a spark, that would have caused an explosion inside the plastic intake. Where it found a spark to set off the explosion, I am unsure, but there should be no fuel inside the plastic intake, only air. With the EGR valve in there also, it is common to have some sludge type of build up, but gas would only be there if you have a leak in the fuel system inside the plastic manifold. I checked my fuel injection system by jumping the fuel pump relay, and looking inside the plastic intake with a mirror and a flashlight, after removing the throttle body. You could also remove the top of the manifold, and reconnect the fuel lines. Here is the video I used to jump the relay. This will turn on the fuel pump, and keep it running while you look at the fuel system for leaks, without starting the truck. The part about jumping the relay is about 18 min. into the video.
Great info, Great video just what I needed to know. My chevy is parked out front and we are in for about 10 in of snow. I have to work on it where it's at. No garage and low funds. I can get parts on ebay cheep.I thank you for the info and will reply when I have some progress.
1 - 4 of 4 Posts
