Hello, this will be my first post on this forum but I've been helped in the past by all the posts on here with different cars. Thanks for all your help.
So, short story: 1996 Chevy Silverado, 5.0, cranks but doesnt start.
Symptoms found:
No spark, fuel pump activates properly.
Replaced:
Crank sensor, coil, coil module.
Long story:
My first guess was the crank sensor, so I replaced it. The old one had a gouge in it, like it was scraping on something. Saw some posts about this being fixed by shims and made sure to put shims under it with the new one from autozone. Didn't fix the issue. Removed shims until no shims, still same symptoms.
Found that it does not have spark to the plugs but also no spark coming out of the coil. Found some useful tips in checking the coil and module next to it, I believe it's called the coil module, and checked their plugs with multimeter - everything normal except signal wire, no volts at all. Didn't backprobe since I didn't know how to do that properly at the time.
Then decided to get another coil that we knew works, still didn't start.
Changed the battery out too.
Went back to autozone to change the crank sensor, thinking its faulty, but that didn't help.
Lastly, I read up on how the crank sensor works and pulled out the good obd scanner we have from the depths of the garage to check the RPM of the engine while cranking. Out of 3 engine rpm numbers it shows, 2 are 0 constantly, even when cranking, and the other one jumps back and forth from 0 to 450 rpm even when not cranking. Doesn't this tell me that the computer does not get signal from the crank sensor? So I checked the cable from crank sensor to computer but it looks fine.
And now we're stumped. Please help... thanks.
Symptoms found:
Replaced:
Long story:
