1 - 4 of 4 Posts
Discussion Starter #1 (Edited)
truck has no spark ..new coil,distributor,cam sensor, still no spark.. no blown fuses. anybody have any input on what i could check.. haw many engine grounds are there in the engine compartment. i only see the the one braded gorund strap. im thinking its a ground wire i just dont no were to look.
Have you checked the ignition module??
Discussion Starter #3
no spark ..yes i replaced it with a new one
yes i replaced it with a new one .. sombody told me ther are 3 engine grounds but i dont no were to look
There is the main battery ground, and then you have the one to the rear of the engine, but what sounds odd is you might have a bad PCM if that rear ground is good.
1 - 4 of 4 Posts
