I have a 1998 Silverado and after my drive to work about 30 min, when i come to a stop it feels like the engine is sputtering and the brake is a little harder to press. if i let off the brale a bit the engine revs up whle stoped then dies. Any ideas? i really need help here. \thanks
This sounds like your brake booster might be dumping vacuum. The loss of vac will cause rough running & also require more pedal pressure from you because the vac assist isn't working. I would check the bb vac hose & grommet for leaks first.
Welcome to the club, kman. I have to agree with stephan.
& welcome to the club Kman. You should fill out an intro in the new members forum & tell us about you & your truck.
