Did you try Rock Auto to see if any of the diagrams are close to what you need?
Yeah, later I looked and they show one hose at a little over 7" and one a little over 5", so that's the ones. However, later double-checking with the parts store and one p/n came up as a power seat switch or something and the other didn't cross-reference as anything. The RockAuto listing for the 7+" hose was an AC elco part and said GM Original Equipment. The 5+" hose was an AC Delco also, apparently a higher level "Gold" replacement part.
I didn't see their names or descriptions though. One bypasses the thermostat to I suppose not dead-head the pump when the 'stat is closed. The other I guess is part of the heater flow circuit. The parts store was finding "heater hose" and showing stock cut-to-length straight hose.
Advance has the 2 different lengths, but the shorter one doesn't confirm the diameter. It's an order-in item, so I didn't mess with it. I found one thing that said you simply cut a 7+" one down to fit in the shorter one's spot, so I'm going that route with NAPA hoses.
