1 - 2 of 2 Posts
2000 GMC Sierra 1500 4x4 extended cab With lift kit my truck turns over but putters out or wont start at all. Plus the battery keeps draining. We changed the fuel filter that didn’t help. The truck was dented on the drivers side a day before problem started. It wasn’t hit though it was dented and scraped while leaving the gas station because someone side swiped the cement pole. I don’t know if that has anything to do with it
Have you tried spraying a little fuel, or starting fluid into the throttle body to see if it will run while you spray?
If it does, you have a fuel delivery problem.
May be the pump, may be the regulator.
If it still won't run, it may be a spark problem.
How many miles, what engine?
1 - 2 of 2 Posts
