1 - 3 of 3 Posts
about the last week my truck needs to turn over about 5 to8 times before it starts.however yesterday morning 1 time fired right up but later on the same thing.
thanks for your help
mike
Have you done a leak down on your fuel pressure and checked the fuel pressure? F/P should be about 60psi. When was the last ime you changed the fuel filter?
Discussion Starter #3
changed the fuel filter friday.doing some checking common for fuel pressure regulator to fail.to check.remove vacuum line from regulator if it has fuel in it thats your problem.bought one chaged it all is ok.
thanks
mike
1 - 3 of 3 Posts
