1 - 2 of 2 Posts
My speedo seems to stick at around 40 mph then jumps to 45 , it doesn't gradualy climb like it should. Also, my fuel guage jumps from empty to full all the time, when I am at idle it sits on empty until I put it into drive then it jumps around finally reaching the right spot. My biggest problem is my truck has started to idle real low and sometimes it even dies. I can start it up fine some days and others it idles around 200 until it eventually dies. I have changed the plug wires and plugs and I will change the fuel filter tonight to see if that is the cause. Anyone had these problems.
2001 Chevy Silverado with Regency Package
4.8 litre V8
105,500 miles
Could be a loose ground wire on the dash, don't know where it is, maybe someone else knows.
1 - 2 of 2 Posts
