41 - 59 of 59 Posts
2001 Suburban 5.3L, 296k miles
Discussion Starter · #41 ·
Weather is going to be nice and cool today. 38F now and 56F later today.
Got the new pan gasket and oil pump pick up tube O-Ring ready to go in.
Time to get started.
  • Like
Reactions: RayVoy
Discussion Starter · #42 ·
Oil pan back in.
Just have to put the cross member back in.
  • Like
Reactions: RayVoy
Discussion Starter · #43 ·
Old o-ring is flattened.
  • Like
Reactions: RayVoy
Discussion Starter · #44 ·
I'm done for the day.
Will put cross member, change oil filter and 6qts of 5W-30 tomorrow.
Cross fingers, will get oil pressure back up
Discussion Starter · #45 ·
Good news!
New oil pump pick up o-ring fixed my low cold start oil pressure.
Got my cold oil pressure back up to 55 psi.
  • Like
Reactions: RayVoy
Discussion Starter · #46 ·
Discussion Starter · #47 ·
I see in yesterday's picture you had a red and a black o ring, I know there is a difference; but for the life of me, I can't find the specs on the net.
Discussion Starter · #49 ·
Ray, I had to go to the dealer to get the red o-ring. It was $10 but I'm sure it is the correct dimension.
The black one is the original o-ring.
I'll see if I can find the dealer receipt.
Discussion Starter · #50 ·
Oil pump pick up tube o-ring: PN 12584922.
Discussion Starter · #51 ·
This is a "Red" colored O-ring from GM.
Approximate dimensions -
Thickness = 4.20mm (0.165")
ID = 20.69mm (0.815")
O-Ring Part Number #12584922 Fits the Following Applications:
W- Body 2006-2008 With LS V8 engine - Impala, Lacrosse, Grand Prix.
Chevy/GMC Pick-Up 1999-2000 LS V8 engines with 2nd design pick-up tube.
Chevy/GMC Pick-Up 2001-2008 LS V8 engines.
Hummer H2 2003-2008
Hummer H3 2008 With LS V8 engine.
Trailblazer 2003-2008 With LS V8 engine.
That's what I saw, people were saving the red one was for trucks.
I'm sure you have the right one, looks like there is a case for leaks around the O ring.
Discussion Starter · #53 ·
My 2001 did not exhibit low oil pressure until 288k miles.
Just have to watch it before it gets worst and score the crank journals and bearings.
Glad I did not dilly dallied. LOL.
I have used synthetic Mobil1 since new and still saw a little sludge in the oil pan. Can you imagine using dino oil?
  • Like
Reactions: RayVoy
Discussion Starter · #55 ·
Ray, the worn black o-ring is actually dark green upon close visual inspection.
It's allowing air to get sucked in from the pick up tube connection to the oil pump.
As you can see in the pic, it's not a round section anymore. The edges were flattened.
Purple Violet Material property Font Body jewelry
  • Like
Reactions: RayVoy
Discussion Starter · #56 ·
Pic of the oil pan sludge.
Also my nasty oil pan leakage was due to the old compressed pan gasket rings unable to seal the pressurized oil filter oil passages in the pan.
Motor vehicle Automotive tire Hood Wood Automotive lighting
  • Like
Reactions: RayVoy
Discussion Starter · #57 ·
Oil pressure update as of Oct. 21, 2021.
Nice 58 psi at 2k rpm even at 295k miles. Can't wait to get up to 300k.
Speedometer Odometer Gauge Tachometer Trip computer
Hey, Bel. Those two ring gaskets. What part number are they, if you recall?
Discussion Starter · #59 ·
If you are referring to the Oil pump pick up tube o-ring, it's below.
Hummer H2 2003-2008
41 - 59 of 59 Posts
