1 - 6 of 6 Posts
My 01 Burb has about 98k and I was thinking about having the trans serviced (no power flushing, just filter, gasket and fluid change), brake fluid flushed and coolant service. I haven't looked at the owner's manual yet, but does the transfer case get servied too?
Yes the transfer case should be serviced every 40,000 miles.
If you have electronic transfer case than it takes AutoTrak ll fluid GM part # 12378508. Its only avaible from a GM dealer. Its about $8.00qt. Takes a little over two qts. so you'll need three.
I would change them both. I use Mobil 1 synthetic gear lube I get fom AutoZone. I also get my Mobil 1 synthetic transmission fluid from them. Get my Mobil 1 engine oil from Walmart.
1 - 6 of 6 Posts
