SAVE YOUR 2002/2009 TRAILBLAZER or ENVOY from the junk yard Many of these SUVs suffer from rear upper trailing arm frame rust/rot Especially in the northern regions of the country I was a victim myself After searching I found that no one had a replacement mount for these vehicles My local frame shop wanted $3000 to repair my rear upper trailing arm mounts I designed these and had my local body shop weld them on for 50% less Offered is a solution to that problem These trailing arm mounts are constructed of high quality plate steel with 12 gauge steel housing complete with brackets for E Brake & Brake line block Installation will require welding to fasten to frame rail by a professional
These are $250 a pair + Shipping Allow 5 to 10 business days after ordering No warranty intended or expressed These are not an OEM part
Thanks for your interest
Contact [email protected]
