1 - 3 of 3 Posts
Our '02 has the 265/70-16 aluminum wheels with worn out Firestone Wilderness LE tires. I'm thinking that since 17" were an option that would be a nice appearance upgrade and keep the 16" for dedicated snow tires.
However, I don't want to introduce speedometer and odometer error by going to the optional 265/70-17 wheel/tire combos.
How do the factory guys do this? is there some speedo electronic setting that is changed via a programmer? Or is it within the speedo error margin anyway?
According to the miata.net tire size calculator, the optional tire size would cause the speedo reading to be 3.3% too slow, or at indicated speed of 60 mph the actual speed is 62 mph.
Your thoughts?
Simple reprogram of the PCM. (Powertrain Control Module) Simple but not inexpensive. My buddy raised his 05 Silverado and went bigger on the tires. He shelled out $500 for a Hypertech to recal the PCM for the change. Silly me, I thought I could borrow it to fix the speedo on my 06, but you can only use it on one vehicle at a time. Since it is a work truck, I just put up with the 3mph difference on the speedo.
1 - 3 of 3 Posts
