2002 suburban 2500, NO HEAT!!!!
3629 Views 1 Reply 2 Participants Last post by  JayMack75
It's funny because the rear air blows hot air all day long but the front does not. I thought maybe it was the radiator therostat but my temp is 195 degrees and holding steady. Maybe the heater core?
1 - 2 of 2 Posts
Check your coolant level. I had a bad problem with that and found out I had a small leak that would eventually drain the coolant to a level that would make the heater blow like A/C. The leak was almost undetectable because when the truck was cool it wouldn't leak but when it was hot it would leak and burn off immediately. Very frustrating.
1 - 2 of 2 Posts
