1 - 3 of 3 Posts
2003 Suburban rough idle changed everything
I have a 2003 Suburban Frankenstein yes the year that Chevy decided to use parts from everything I have changed just about everything on the truck yet I still showing random misfire code po300 my HP scanner shows a misfire in cylinder 2 and 6 only I've run out of ideas can you help
Reply Quote
RayVoy
RayVoy
Joined Apr 18, 2012 · 15,652 Posts
#2 · 52 m ago
Have you tried a compression check on those cylinders?
Ray
'09 Avalanche LTZ - 5.3 - 4x4 - Black
Reply Quote
Like
Jpatch
Jpatch
Joined 1 h ago · 2 Posts
Discussion Starter · #3 · a moment ago
Yes compression was around 1:25 to 1:30 I'll go on cylinder number to it seemed to be a little erratic but if I let it crank maybe 7-8 10 times it showed 130 final as soon as you accelerate over a thousand RPM it runs like a champ it runs like a champ I can manipulate the timing and air fuel with my HP tuner and it'll run beautiful turn off the ignition go have a beer when I come back it reverts back to its old rough idle I can't figure it out I think something with timing
Reply Quote
I'm assuming a 5.3.
And it does sound like timing, maybe you should try a crankshaft position relearn.
Two threads are always confusing, let's use the other one.
1 - 3 of 3 Posts
