1 - 7 of 7 Posts
Just be sure the transfer case is in Neutral, if not, you will destroy the transmission.
By the way, all of this info should be in your owners manual, if you don't have one, they are available online
Should take up to 10 seconds for it to shift into neutral, as I recall. I would still check the owner's manual to see if it safe to tow, though. For a short distance you will be okay, as in a hundred yards or so. I'm not sure if it meant to tow a long distance at highway speeds.
1 - 7 of 7 Posts
