1 - 3 of 3 Posts
I know this has been discussed several times on this forum since it is a common problem. The heater will come on while in AC mode on the drivers side only. I can turn the truck off and back on and the problem fixes itself. Is the fix as simple as replacing the actuator on the drivers side? It seem that if the actuator was bad, turning the truck off and back on again wouldn't fix the problem.
1 - 3 of 3 Posts
