1 - 10 of 10 Posts
I replaced the one at the bottom center of the dash to fix my heat/cold problem.
Now I have a front vent not working problem. I think its the one at the center top of the dash.
BUT I also hear clicking under the drivers dash. Is there another one hiden there also?
Are all these the same module?
Anyone have any idea?
Do you have manual controls or digital/automatic?
Then you’re going to have a temp door for each side, a mode servo, and a recirculated air door. So four by my count.
Discussion Starter #7
Im' not having much luck finding if they are al the same part and interchangeable or a different one form each spot
I also cant find a scamatick to figure out where they are. Most Searches show the blend hot/cold door at the bottom of the dash.
For mine there is an upper main and a lower unit and I had to pull the cover off the bottom of the dash in order to verify which one was making the noise.
While you’re at it, you may as well replace the cabin air filters. They’re easily accessible behind the valence between the lower servo and the blower motor.
1 - 10 of 10 Posts
