OK, I had the same problem on my 02 LT. I asked the dealer, and they said it was normal too. After some searching and digging though 2+ years of info on 4+ forums, I found someone else who had the same problem and fixed it by gently bending the tops of the front windows. I tried it, and it worked great! I still have the noise going 75+ with a strong sidewind, but other than that, no problems whatsoever.
Open the door, and grab the top of the frame as well as holding the rest of the door open, and apply downward pressure to the top of the door. Close door to make sure it still closes properly, and test. Keep doing this until the noise is gone. Worked for me, so I hope it will work for you too!
