1 - 1 of 1 Posts
Started getting error code P0894 and when I checked the fluid is was way over serviced as in about 2-3 inches above the full hot mark that and it was a pink color on the white rag not red. Also the trans temp was higher than normal. So I figure the radiator is leaking into the transmission at the cooler/heater. When I dropped the pan this is what I found at the bottom and stuck on the filter inlet.
The pieces have straight edges and when I looked up a repair kit I don't see anything with straight edges, some are too big to fit through the 3/8 lines going to the cooler.
Any ideas would be much appreciated!
Brown Wood Rectangle Font Tints and shades
1 - 1 of 1 Posts
