1 - 2 of 2 Posts
I need some help im getting fuel van turns over but no spark ive replaced everything to do with the spark even changed out fuse block terminals were bad off ive spent almost 450 in sensors n everything else for that matter n it doesnt have coil packs ive checked all grounds frame ,motor, n ne other ground that ive watched youtube videos on pleez help thank u
I'd suggest starting with your coil. Check the connector going into your coil - does it get power and a good ground? Do you get spark coming out of your coil?
1 - 2 of 2 Posts
