1 - 4 of 4 Posts
I was wondering if you guys could tell me how to drop the pan it seems to be stuck on the shift linkage i bolted it back up and put fluid in it because i need it tommarow it (my favorite car of are five lol). But will be working on it sunday because the filter needs changing bad.
The linkage bracket needs to come off. It takes a #40 torx bit to remove. If your laying on the ground (no lift) its a pain in the as*.
just unbolt the linkage and push it out of your way, dont forget to rebolt it like i did. put a corvette shift servo on while youre down there!
Discussion Starter #4
I was thinking of doing the vette shift servo is it very hard to install and also where should i pick it up.
1 - 4 of 4 Posts
