1 - 9 of 9 Posts
Howdy all. Newbie member here, and this is my 1st post. My better half and I just traded for a 2006 Silverado 1500 (our 1st Chevy truck) yesterday, and I have a question(s). Is there an online guide for deciphering the VIN?? I need to figure out a couple of options, and the option level. I know that it is an LT, but not which level of LT (1, 2, or 3). Also, which 5.3 engine (I do know it's not the multifuel version), and which rear axle ratio that I have (I do have the towing package). Any suggestions? Thanks in advance :cool:
patrad.
Edited to add: Forgot to add that I'm also the original owner of a 69 Camaro - 95% original, except that I've had it painted (lacquer as original) in 98-99. Plain jane, 327, powerslide, a/c, ps. Trophy in every show I've put it in. App. 85,000 original miles. Lemans Blue. When I learn how to post a pic, I'll post one of the car & truck.
Welcome fellow 2006 Silverado owner!:great:
You might try vinquery.com
For as little as a buck, you can get the info you want at: Vinquery.com
Below is the "Extended" info I got for $1.90. I didn't get specific info about the engine/trans/rear end for my inquiry. Your results may vary.
VINquery.com Report - 5/28/2007 VIN # 1GNFK16K1PJ3XXXXX VINquery.com Vehicle ID 15139 Model Year 1993 Make Chevrolet Model Suburban Trim K1500 4WD Manufactured In UNITED STATES Production Seq. Number 3XXXXX Specifications - General Body Style SPORTS UTILITY 4-DR Engine Type 5.7L V8 OHV 16V Transmission 4-Speed Automatic Overdrive Driveline 4WD Tank(gallon) 42.00 Fuel Economy(City, miles/gallon) 12 Fuel Economy(Highway, miles/gallon) 16 Specifications - Chassis Anti-Brake System 4-Wheel ABS Steering Type Recirc Brake Type(front) Disc Brake Type(rear) Drum Turning Diatmeter(in.) 47.80 Suspension(front) Ind Suspension(rear) Live Spring Type(front) Torsion Bar Spring Type(rear) Coil Tires 225/75R16 Specifications - Interior Dimensions Headroom(front, in.) 34.70 Headroom(rear, in.) 39.30 Legroom(front, in.) 41.80 Legroom(rear, in.) 36.60 Shoulder Room(front, in.) 66.00 Shoulder Room(rear, in.) 66.10 Hip Room(front, in.) 60.50 Hip Room(rear, in.) 59.60 Specifications - Colors Interior Trim No data Exterior Color No data Specifications - Exterior Dimensions & Weight Curb Weight(automatic, lbs.) 5238 Curb Weight(manual, lbs.) No data Length(in.) 219.50 Width(in.) 77.00 Height(in.) 68.80 Wheelbase(in.) 131.50 Ground Clearance(in.) No data Track(front, in.) 64.10 Track(rear, in.) 63.10 Specifications - Cargo Bed Dimensions Length(in.) No data Width at Wheelwell(in.) No data Width at Wall(in.) No data Depth(in.) No data Specifications - Capacities Seating(standard) 3 Seating(optional) 2 Volume(passenger, cu.ft.) No data Volume(cargo, cu.ft.) No data Towing(standard, lbs) No data Towing(maximum, lbs) No data Payload(standard, lbs) No data Payload(maximum, lbs) No data GVWR(standard, lbs) No data GVWR(maximum, lbs) No data Specifications - Warranty Basic(duration, months) No data Basic(distance, miles) No data Powertrain(duration, months) No data Powertrain(distance, miles) No data Rust(duration, months) No data Rust(distance, miles) No data Specifications - Pricing MSRP(USD) $21,370 Dealer Invoice(USD) No data Destination Charge(USD) No data
1 - 9 of 9 Posts
