1 - 3 of 3 Posts
Hello everyone, need help with a problem.
4wd just up and quit, working fine one day next day needed it for muddy ground and nothing.
It is in 2wd and when switch to auto/4h or 4lo the light will blink for awhile in that location, 4wd or auto does not engage and the light goes back to 2wd.
Just installed a new actuator and it did not fix the issue.
Noted an odd sound, after removing the old actuator I was struggling with the plug I heard a click from where I removed the actuator.
Do I have a bigger problem?
or could it be the switch in dash?
I thank everyone in advance for any and all help...
Discussion Starter #2
Would a failed transfer case motor (encoder) cause this problem?
or would symptoms be different?
No fault lights (engine/4wd) are on
only the selector light as noted above,
Thanks again
Discussion Starter #3
Just had some help, with someone inside key on an in N
Had them switch to 4Hi
The transfer case motor made a slight click or 2 and then just hummed
What sound should I hear? (if it's working properly)
Also, unpluged it and checked pins, all were clean
The transfer case motor looks to be factory original
1 - 3 of 3 Posts
