Make : CHEVROLET
Model : AVALANCHE 1500
Year : 2007
Manufacturer : GENERAL MOTORS CORP.
NHTSA CAMPAIGN ID Number : 06V307000
Recall Date : AUG 09, 2006
Component: WHEELS:RIM
Potential Number Of Units Affected : 3227
Summary:
CERTAIN SPORT UTILITY VEHICLES AND TRUCKS FAIL TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 110, TIRE SELECTION AND RIMS." THESE VEHICLES HAVE AN INCOMPLETE TIRE RIM DESIGNATION ON THE CERTIFICATION/TIRE LABEL LOCATED ON THE DRIVER'S DOOR EDGE. IN ADDITION, THE LABEL MAY ALSO BE MISSING THE TIRE LOAD RATING ON THE LABEL. ALTHOUGH THIS INFORMATION IS NOT REQUIRED BY THE STANDARD, IF A TIRE OF A LESSER LOAD RATING IS INSTALLED, THE TIRE MAY NOT BE ABLE TO SUSTAIN THE LOADS ENCOUNTERED DURING USE.
Consequence:
IF A CUSTOMER REPLACES A WHEEL AND ONLY RELIES ON THE RIM SIZE DESIGNATION THAT IS INDICATED ON THE LABEL, A WHEEL THAT IS OF A DIFFERENT RIM CONTOUR DESIGNATION MAY BE INSTALLED. IT MAY BE DIFFICULT OR IMPOSSIBLE TO MOUNT THE TIRE ON A WHEEL WITH THE WRONG CONTOUR. IF THE TIRE IS MOUNTED ON THE WHEEL WITH THE WRONG CONTOUR, THE WHEEL AND TIRE MAY NOT PERFORM AS INTENDED, WHICH COULD INCREASE THE RISK OF A CRASH.
Remedy:
A LABEL THAT WILL CORRECT THE LABEL ORIGINALLY INSTALLED WILL BE MAILED TO CONSUMERS ALONG WITH INSTALLATION INSTRUCTIONS. THE CUSTOMER WILL HAVE THE OPTION FOR DEALERS TO INSTALL THE LABEL. THE RECALL BEGAON ON NOVEMBER 7, 2006. OWNERS SHOULD CONTACT CADILLAC AT 1-866-982-2239, CHEVROLET AT 1-800-630-2438, AND GMC TRUCKS AT 1-866-996-9463.
Notes:
GM RECALL NO. 06079. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONS VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
GM Truck Club Forum
A forum community dedicated to all General Motors truck owners and enthusiasts. Come join the discussion about performance, lift kits, wheels, tires, modifications, troubleshooting, maintenance, and more!
