I have a 2008 silverado LT crew cab and in the daylight, I can see two bulbs inside the clear panels so I assume they must work? How does the cargo light turn on?
I have checked the manual and have had a truck before where you actuate that light by rotating the dimmer switch all the way to the right but when I have tried that, nothing turns on outside the cab, although the overhead dome lights inside do turn on as they should.
I briefly checked the fuse panel and didnt see anything blown, but am not sure if the inside panel would even control that fuse?
In any case, can someone please help out here? Thanks!
