Well, that 2008 Chevy Silverado trucks are here. The nice folks at Chevy let me get behind the wheel for a test run, and I put it through it's paces, that's for sure.
The Truck
2008 Chevy Silverado 1500 4WD Crew Cab LT2
MSRP: $43,025
What's it like to drive?
You'll think your driving a comfy luxury car. This is perhaps the best driving truck I've been behind the wheel of. Now that GM is in the 2nd year of the current body style, most of the kinks have been worked out of the design process from the 2007 (like the hard-to-read instrument panel when wearing sunglasses). It's a well put together package that I enjoyed very much.
The test truck had the standard 5.3L V8 with the 2nd year active fuel management, this gives you the power that you need when you need it, and better fuel economy when running at a steady speed or when coasting downhill. I never felt at a loss for power and still managed to get near 17 MPG all around driving.
Perhaps the biggest improvemnt for 2008 can be found in the steering and braking. I found the steering to be very easy, almost like it was electronic and I wasn't actually turning a physical shaft. Nevertheless, it was also tight and responsive at the same time. Hats off to the guys at GM on that one.
The built-in navigation package (optional) has matured a bit as well. It appears to be much faster-loading, which is great when you've sometimes got very little space to makes a couple of turns, while watching traffic too. We even typed in "Little Caesers" and found a pizza joint to get a bite to eat. Gave us turn-by-turn directions.
The 4WD on the dial technology is better as well. It's even easier than ever to go into 4-high or 4-low, or set it to AUTO and let the computer handle it for you. We managed to find some more mud (ok, it was the SAME mud hole that I took some of the other Silverados to) and we had no fear of getting stuck in the ruts. Everything when smoothly.
What's it like to sit in?
Not a lot has changed from the 2007 Silverado to the 2008. There is still a lot of leg, head, hip and shoulder room. In my big and tall state I have no problems sitting comfortably, even for long periods of time. I may be dreaming, but there even seems to be more room for my left-foot, under the pesky parking brake.
I still think the stereo controls are a bit too far away, but I was still able to reach them and they are almost all duplicated on the
This is a 4WD pickup truck. You do sit up higher than most cars. You are heavier and it takes a while to stop. Make certain to drive like it. I found this out in traffic when 200 cars went from 70 to zero in about 10 seconds (me included) becuase of a just-happened accident up ahead. The 4-wheel anti-lock brakes locked up and stopped this beast on a dime.
Toys and Gadgets
For 2007, I'm still hooked on the XM and the built-in DVD system and GPS navigation system. If you're going to spend this much on a truck, you may as well splurge and get the unit that you really want.
The DIC is also very impressive as well. From a glance you can get a view of report of the active MPG you're getting, tire pressure, transmission temp or a variety of other stats that you may need to know when going down the road.
Overall impression?
Thumbs up and hats off for the 2008 Chevy Silverado. It's comfortable, quiet, has plenty of power and looks great too.
Some Notable Standard Equipment - Test Truck
5 year / 100,000 mile powertrain limited warranty
Vortec 5.3L V8 w/ 4-speed Auto Transmission
Z85 Handling / Trailering Suspension
4 wheel ABS
Tire Pressure Monitor Sytem
Driver Information Center (DIC)
1-year OnStar Safe & Sound
Some of the Options
Remote Vehicle Starter
Heated Window Washing Fluid (hah! in Texas?)
Navigation Radio CD/DVD/MP3 with rear seat entertainment system
Power sliding rear window
Leather seats
XM Satellite Radio
Cargo Management System
The Truck
MSRP: $43,025
Toys and Gadgets
Overall impression?
4 wheel ABS
Some of the Options
Leather seats
XM Satellite Radio
