1 - 7 of 7 Posts
Hey guys quick help needed here. I'm trying to install an amp in my truck and i'm keeping the orginal HU so i just need to know where i can find the color codes for the radio wiring. I'm going to splice it to the left speaker. Your help is appreciated
Manny
We need to know what you are doing, factory HU + factory speakers + amp = no good, factory HU + new speakers + amp = wait to you can afford a new HU New HU + speakers + amp + new wiring =:great:
OEM HU + OEM Door Speakers + AMP + 2 , 10' Subs'
Hey guys its all figured out already. I installed two 10'' inch Memphis audio's in a downfire box with a 1000 watt Memphis Audio amp and kept the origanal HU and factory door speakers. It was a good buy my friend was selling all three for 150 bucks. :sign0011: I'll be buying different door speakers and tweeter's once I blow out the factory ones that I have. I used my HU's dimmer wire (yellow wire on the right side when looking at it from the seat) as my remote. That way if five O is near me at the stoplight i just drop down the dimmer light on the radio and the system is off :na:. I bought an RCA conversion kit and tapped into my front right speakers by the kick panel on the passenger's side. The wire colors are light green (+) and dark green (-). I split the rca with a Y adapter and plugged into both ports. I adjusted my amp so that I don't have to use much bass on the HU its like two clicks below medium. Tell you the truth it sounds freakin awesome especially for what I paid.
remote wire
be careful having the remote connected to the dimmer because I have had people come into my shop complaining that their dash lights went out and it was because something was being powered off the dimmer. i would suggest you go to the ignition harness to get the remote off a true acc.
I connected my remote wire to the very dark brown wire that is part of the ignition harness. There is a strip of vertical wire harnesses. The dark brown wire is in the top harness its sort of a teal color. I just hooked mine up and put a little paddle switch on my dash right beside the steering wheel column
1 - 7 of 7 Posts
