1 - 4 of 4 Posts
I have a 2011 Silverado LT, so it comes with the radio and panel that has the air vents to the left and right of the radio.
How do I remove the dash trim?
I know this is like the 1,000th question. But I have searched the entire net for the past 6 hours at work and cannot find anything!
You should be able to pull out on the top corners to start it off.... there are 2 clips at the top, one on the right side and three on the bottom I believe. The plastic trim below it comes off the same way....you may want to pull the top clips of it out becasue the bezel around the radio sits behind that lower bezel..... I am pretty sure yours is like mine:
Vehicle Car Electronics Multimedia Technology
The trim around your AC controls is separate...it can be taken off after the main bezel has been removed if needed.
Yeah pretty much the same exact setup but I have the 4x4 knob selector and my a/c controls are digital. So hopefully all I have to take off is the big main bezel around the radio to access the screws.
That dash trim is sick! Where did you get something like that?
1 - 4 of 4 Posts
