1 - 7 of 7 Posts
My Colorado recently started honking 3 times whenever the doors are closed. Does anyone know how to fix this?
Closed, or locked?
There are horn honking options available when using the remote key fob.
Check the owners manual
Discussion Starter #3
Closed, or locked?
It happens whenever I shut the doors closed. I've looked through the manual and I couldn't find anything about it.
Ok then, could it be because the truck shakes a bit when the door closes?
Maybe the horn relay?
Check the dashboard user settings. The modern trucks (sister has a 2019) beep when you close the door, so it's normal. Might have something to do with the proximity lock settings, too.
1 - 7 of 7 Posts
