1 - 4 of 4 Posts
I bought a 3" leveling kit for my 04' 2500hd and I havent installed it yet.. I was just wondering if this
aftermarket leveling kit will be any different than what i've got my torsion keys cranked up to now ??
They're already cranked up all but 1/8" on each side, so will this aftermarket 3" leveling kit do anything more than
what i've already done myself by tightening the oem torsion keys ??
Some kits claim to be 2", some say 3" .. I bought this kit from eBay for $47.95 and it claims to be 3".
So what should I really expect from this cheap leveling kit?
Every trucks a little differance. It depends on what torson bars came on the truck. GM makes about 20 differant torson bars, thats why some guys get 1" of lift and others get 3" of lift with torson keys. Becareful of cheaply priced torson bar keys, some are made in China (junk!!).
I'm probably gonna need to buy the shock extensions before installing the keys, of course I opted for the cheapest
torsion keys I could find, $47.00 (cheap!) compared to others.
I cranked up the oem torsion keys pretty much to the max, and you can certainly feel every bump in the road!
The only rubbing of the tires i'm getting is when I put it in REVERSE and turn the wheel ever so slightly.. It's got some rubbing on the passenger side.
Most cheap keys are cast and the more expensive are forged. Can you send the keys back for a refund? Then get a ReadyLift that comes with forged keys and shock extensions.
---------- Post added at 07:39 PM ---------- Previous post was at 07:35 PM ----------
One other thing, with the so-called 3" lift keys you end up bottoming out the suspension travel and you can over extend the front CV axle joints causing them to wear or break prematurely. Plus sometimes it will cause the CV boot to pull loose.
1 - 4 of 4 Posts
